by PyroTempus
Using contract sim in another phone
I'm wanting to upgrade to an iPhone 11 Pro Max. I'm currently on contract with an Android device. If I put the sim from my Android device into an iPhone 11, will I still be able to use my minutes, data and texts the same until my contract runs out?
Solution
Re: Using contract sim in another phone
Hi @PyroTempus
Welcome to the community.
As the SIM fits and the phone you're using is unlocked or locked to EE, you'll be able to use your SIM in it.
If you need a different sized SIM card, we can send you a replacement
Chris 🙂
by Ace Contributor
Hi @PyroTempus
Welcome to the EE Community,
yeah that's perfectly fine.
Thanks,
David.
Solution
Hi @PyroTempus
Chris 🙂
by Ace Contributor
@PyroTempus if you need a replacement  SIM the account holder can pop into any EE store across the UK with photographic ID and they will provide you with one free of charge.
