by lkwilson
USA Citizen Looking for a data plan while traveling to Manchester and Edinburgh
I've a few friends traveling to Manchester, London and Edinburgh for couple of weeks.  They'll need a dataplan to use with Samsung Galaxy 6 (or 6S)    Suggestions?  Thanks All
Re: USA Citizen Looking for a data plan while traveling to Manchester and Edinbu
@lkwilson  If you’re friends don’t need a call or text allowance you can purchase a preloaded data only SIM card three can be found on eBay, Amazon or any EE store Or it’s a payg SIM card just pop in to your local EE store or have a look at THIS
EE Employee
Great info @Chris_B
Smiley Happy​​​​​​​
by Profile closed
Not applicable
@lkwilson Just make sure your handset isn't SIM locked though.  If it is, a different SIM card won't work in it.
The handset will also need to be compatible with 4G/LTE bands 3 (1800Mhz), 7 (2600Mhz) or 20 (800Mhz).
EE do mostly use band 3 for LTE though, as well as band 1 (2100Mhz) for 3G and band 3 (1800Mhz) for 2G.
by lkwilson
Thanks!  Good info.   I'll double check to make sure their sim is unlocked, it qualifies, but they probably haven't done it.  Thanks again!
