by Jamesdyer98
SIM card replacement using same number
Ive lost my contract SIM card, if I were to replace it would the replacement SIM carry the same phone number across from the previous, lost sim?
by Ace Contributor
Solution
Re: SIM card replacement using same number
Hi @Jamesdyer98
1st of all ring mobile care team on 150 and report your sim lost or stolen to avoid any unauthorised use.
You can ask them to send you replacement sim via post that can take up to 5 days or go to nearest EE Store and you can get replacement sim with same number free of cost on spot.
by Ace Contributor
Solution
Hi @Jamesdyer98
