by Chelza12
S7 screen cracked and going for repair. Can I use sim in s5 phone?
 S7 going for repair to screen. Can I use my s7 Sim in s5 phone?
by Brilliant Contributor
Solution
Re: S7 screen cracked and going for repair. Can I use sim in s5 phone?
@Chelza12 Yes but You will need an adaptor as the s5 is a micro and your s7 a nano
If it fits then yes you can.
Solution
