by Cutie Established Contributor
Replacement phone arrived put sim in lost all contacts?
Put sim in new phone I have lost all my contacts how can I get them back?
6 REPLIES 6
Put SIM from old phone in new list all my contacts!
How do I get my contacts back? Put SIM card into new phone
Re: Replacement phone arrived put sim in lost all contacts?
If you haven't backed them up online (iCloud, Google, Outlook, Samsung, WhatsApp etc..) then they will be on your old sim.
Hi it is the same sim I took it out old phone and put in new one. I had to reinstall whatape on new phone so had no contacts on there either 😞
Hi @Cutie,
It sounds like your contacts were stored in your phone's memory, rather than on your SIM card.
What type of phone did you have?
Yes I think so! ! My new phone is a Samsung galaxy s4 previous one Samsung mini
Hi @Cutie,
Did you log in to your Google account when setting up your new phone?
