by Mummytoherbabie
New Member
Replacement E sim
My E sim never transferred to my new devise now it seems to be in limbo so my big question is now do i get it back or get a replacement E sim with the same number ?!
by Ace Contributor
Solution
Re: Replacement E sim
Hi @Mummytoherbabie
Welcome to the EE Community,
If you pop into any EE store with photographic ID they will be able to provide you with a new esim pack free of charge alternatively customer services can send you one for a charge of £1.50
Thanks,
David.
by Ace Contributor
Solution
Hi @Mummytoherbabie
Thanks,
David.
Recent solutions
