by HenryH
Recommendation for eSIM plan for a visitor?
I'm a Canadian who is planning a trip to Europe from Apr 5 to May 18 2020 visiting the UK, France, Italy, and Greece. I have an iPhone 11 Pro with eSIM capability.
Is it possible to get the eSIM and a PAYG plan in advance of my trip? How about a FLEX plan instead? Do you have any recommendation about a better way to get voice/text/data service for 6 weeks in these four countries?
by Skilled Contributor
Skilled Contributor
Solution
Re: Recommendation for eSIM plan for a visitor?
EE don't issue eSIMs on PAYG or Flex plans; only on contracts, which you would be ineligible for as you'd have no UK credit record. You could get PAYG or Flex plans from EE but only with a conventional SIM.
Skilled Contributor
Solution
