by XenonArcher Investigator
Number not recognised
Hi, i ordered 2 free sims from yourselves and i just received them both, however, i cant register the numbers as the site doesnt recognise either of the numbers (ordered 2 sim cards)
im not sure what is causing this
6 REPLIES 6
Re: Number not recognised
I should add some details.
So, i inserted my sim into my phone and went to EE.co.uk/join, registered an account then tried to register my number. I input said number correctly, 4 times, and it always said number not recognised. Is there something im missing here?
Hi @XenonArcher
Welcome to the community. 🙂
Just a few questions.
Are they pay monthly or pay as you go SIMs?
Does the phone show a signal in the top corner of your phone?
Are you able to try a test call to 150?
Yes, they are both pay as you go sim card.
yes, my phone shows a signal
and no, it wont call anything as its still in emergency mode. it says "not registered on network" if i try to call 150
Hi @XenonArcher,
Have you topped up your SIM cards?
Are you in the UK?
Yes, im in the UK.
Is topping up the sim card required for it to work? cus giffgaff payg sims didnt require it and id rather not spend money on something that im uncertain will work.
like, i tried to ring the number from my house phone and it was unrecognised. EE's own website doesnt recognise either of the numbers and none of the steps the booklet told me to do work
EE Community Team
Hi @XenonArcher,
To be able to make calls on a new pay as you go SIM card, you will need to top up the account.
Have you been able to receive a call on any of the numbers?
Alex 🙂
