by gloinature
Need phone, sim card, pay-as-go for UK use & able to swop out sim for US use.
I live in the US. I'm visiting the UK in March and thinking of  buying a Samsung Galaxy J3 2016 with a sim and EE pay-as you-go monthly plan (buying only a month at a time) that also gives me the ability to switch out the sim card for a US service provider when I'm back in the US. (I've researched AT&T as a possible US service provider.) If this is truly feasible, then I'd have a mobile set-up I can use when I go back and forth between the US and the UK. Your thoughts, anyone?
by Ace Contributor
Re: Need phone, sim card, pay-as-go for UK use & able to swop out sim for US
Hello @gloinature you need an unlocked device to use a UK and US SIM card in.
You can purchase the Samsung J3 from an EE store along with an EE SIM card and request the unlock through EE:
https://community.ee.co.uk/t5/Unlocking-your-device/How-to-unlock-an-EE-pay-as-you-go-phone-or-devic...
Or buy an unlocked device on its own then just get an EE SIM card. They are available in most UK airports and shops.
EE Employee
Hi @gloinature and welcome to the community.
Hope you find the advice given above by @tm90 of great help 🙂
Many thanks,
Lee
