by Cutie Established Contributor
My phone has to be returned for replacement and I can't use my sim in old phone
I have to return my phone for a replacement and my sim card doesn't fit old phone any ideas other than get pay go sim for old phone which means changing my no!
Re: My phone has to be returned for replacement and I can't use my sim in old p
You can order another sim via EE or go into store and pick one up for free.
Thank you my son has an adapter so can use the same SIM 🙂 thanks again
Excellent, @Cutie.
I'm glad you managed to get sorted.
Let us know if you need anything. 🙂
