by Heeji
My mobile data, calls and texts are not working
I had bought SIM card few days ago
and I had just associated it
but my data, calls and texts are not working.
I am using iphone XR
Re: My mobile data, calls and texts are not working
Hi @Heeji
Have you tried resetting your network settings.
Go to Settings > General > Reset > Reset Network Settings.
If this does not work, are you with us on pay as you go or pay monthly?
Also, is the iPhone unlocked?
Leanne 🙂
by Heeji
I have
switch off/on phone, take out and reinsert the SIM, toggle the flight mode on/off, turn on data roaming,
reseted network settings several times.
I still have difficulties with using my data, text and calls.
I am using PAYG, and my iphone is unlocked.
Is there any other possible method that I can do?
Hi @Heeji
Thanks for coming back to me.
Has the iPhone worked with an EE SIM card previously?
Can you receive calls and texts?
Leanne 🙂
