Highlighted
by Valued Contributor
Valued Contributor
Invalid card
Hello. 3 years ago I bought the number EE but last one year I didn’t use the number and now is not valid. I need help and i beed again this number valid cuz i need to speak from him
Highlighted
by Ace Contributor
Solution
Re: Invalid card
How long is it since you used the sim card?
If you haven’t used the sim card for any chargeable activity for 179 days, your account will go into hibernation and any credit will be removed. But it’s not too late to reinstate it at this point.
After 269 days of inactivity, EE will send you a text to let you know the number will be disconnected within 24 hours.
After 273 days the number will be recycled and lost.
Chargeable activity is:
  • Voice and data usage. This includes making calls, sending text messages and picture messages, retrieving a voicemail, and using data that is not within your pack or add on.
  • Topping up your account.
  • Buying a pack or an add-on.
7 REPLIES 7
Highlighted
by Ace Contributor
Solution
Re: Invalid card
Highlighted
Valued Contributor
Re: Invalid card
How I said I didn’t use since one year. Haw can i do active again. I really need to
Highlighted
by Ace Contributor
Re: Invalid card
If it's a full year (365 days) since last used. Then you will be unable to get it working again, as after 273 days the number will be recycled and lost.
Highlighted
Valued Contributor
Re: Invalid card
Ok then the solution is to buy a new card with new number
Highlighted
by Ace Contributor
Re: Invalid card
That is correct.
Highlighted
Valued Contributor
Re: Invalid card
Ok. Thank u so much and sorry for bothering u darling. Have a lovely evening and take care
Highlighted
by Ace Contributor
Re: Invalid card
You are very welcome, no problem at all. You have a lovely evening to and take care.
