by Ismj61 Investigator
I activated a sim earlier. First attempt to make a call it says calls aren’t bei
13 REPLIES 13
Re: I activated a sim earlier. First attempt to make a call it says calls aren’t
Please complete the error msg. Calls aren't what?
Are you in UK?
by Ace Contributor
Hi @Ismj61
Welcome to the EE Community,
Is it a Pay as you go or Pay Monthly sim ?
Calls aren’t being allowed. It’s in UK, pay monthly
Pay monthly
by Ace Contributor
What exactly does it say ?
Calls aren’t being allowed from this number.
by Ace Contributor
@Ismj61 I would contact technical support on 0800 956 3146 from a landline from 8AM.
Thanks. Doesn’t help with an impatient 18 yr old when I can’t use a phone between 8:00 and 16:00 though
by Ace Contributor
@Ismj61 sorry we are only customers like yourself.
Yeah I get it. I’m trying the old turn it off and back on again
by Ace Contributor
@Ismj61 your best bet is ring that freephone number I give you from a landline that will allow the advisor to run through all options available to themselves while your on the phone.
Where are you?
Can you send texts and use data?
Morning @Ismj61
Are you able to receive calls?
The number you are trying to call is this a UK mobile or landline number?
Hope to hear back from you soon.
