by AnnMellish
How to get SIM card for iPhone 5
Been given an IPhone 5 but SIM card from old iPhone too big - how do I get SIM card for iPhone 5
by Star Contributor
Star Contributor
Re: How to get SIM card for iPhone 5
Hi @AnnMellish
You should be able to get one from your local EE store.
Thanks,
Martyn
Hi @AnnMellish
Welcome to the community. 🙂
@martyn413 is correct, you can get a SIM card from your nearest EE store.
If you have a multi-SIM, which is the latest type of SIM card, it holds all three formats (nano, micro and standard) in one. You simply pop out the size you need (Nano SIM for iPhone 5).
Find out more information about SIM card sizes >
Hope this helps. 🙂
