Highlighted
New Member
How much does a replacement sim cost...?
How much does a replacement sim cost....?
Highlighted
Solution
Re: How much does a replacement sim cost...?
Take phone & SIM into an EE shop with Photo ID & they'll transfer number, any SIM contacts & credit if applicable to a replacement SIM of correct size for free or order a replacement SIM online at Order a replacement SIM or phone CS for one for £1.50.
You can only use the online form when you just need a different sized SIM for a new phone.
Highlighted
Solution
Highlighted
by Investigator
Personally i think the £1.50 charge should be removed as we are not able to go to shops to get it changed in this COVID19 climate.
Highlighted
Morning @zinao75
If you speak to our Mobile Care team, they will be able to help you with the replacement SIM card and see what they can do about the charge.
Thanks.
