by howsey
How long does it take for a simswap to activate?
I have a new Samsung A5 and need to do a simswap as previous sim doesn't fit, but it's been 15 hours since I did it and still not activated, how can I tell if it's actually in progress or I've messed up and I need to re-do the process?
EE Employee
Re: How long does it take for a simswap to activate?
Hi @howsey and welcome to the community.
How did you process the SIM swap?
Have you tried popping the phone off and back on?
Many thanks,
Lee
by howsey
I followed all the onscreen instructions I've, getting code sent to old phone and inputting into new etc. Both phones now have no connection to operator.
i called business support who said their having server issues at ee and hopefully should be ok this time tomorrow ? ...but would turning off and on upset their activation processs ?Thanks
EE Employee
Turning the device off and back on will not effect the transfer.
Is you line back on.
Many thanks,
Lee
