by afrs Investigator
How can I get a replacement Sim card?
When I bought my EE mobile phone you acepted my EU ID card as valid document.
However, now to get a SIM card replacement you dont't acept my EU ID card as valid document.
Very nice! Very good customer service!!
@XRaySpeX wrote:
Take phone & old SIM into an EE shop & they'll transfer number, credit & (SIM) contacts to a replacement SIM of correct size for free or order a replacement SIM online at https://explore.ee.co.uk/Order-a-new-SIM for £10.
17 REPLIES 17
Re: How can I get a replacement Sim card?
Hello there @afrs
Aare you with us on pay as you go or pay monthly?
Have you lost your SIM card?
Speak soon, Leanne.
Hi Leanne,
I have a  EE pay monthly plan.
My SIM card is the Standard one and I need replacement to a Nano SIM card to use it in a new device.
@afrs: You could use the online form https://explore.ee.co.uk/Order-a-new-SIM . It's now only £1.50.
Hi @afrs
Thanks for coming back to me.
You can order a SIM online as @XRaySpeX has advised.
Or, you can give us a call and we can order you a SIM to be posted out.
Hope this helps 🙂
I really, really disapointed!!!
After try to get a new SIM card in a EE shop and they didn't acept my EU ID card I followed you instructions and ordered a new SIM card online form https://explore.ee.co.uk/Order-a-new-SIM.
SURPRISE!!! I received at home the same SIM card (exactly the same size) I have in my old mobile phone.
Incredible!!! That's the most dificult thing to do. Change a MICRO SIM CARD for a NANO SIM CARD.
CRAZY!!!
@afrs: You sure it's not a combo-SIM where you press out the size you want? That's what EE usually send out.
Yes! There's a combo - SIM (standard) and Micro SIM
Doesn't have NANO SIM.
And more: the card show SIM and Micro SIM.
@afrs: Surely it does? The little white 1 in the middle. Might not be too obvious. EE only use 3-part combos.
by Ace Contributor
Hi @afrs
 Look at this Picture ee All sim are like that.
NO! That is I'm looking for.
@afrs: Are you on TMobile? They seem to have sent you a TMobile SIM. Maybe TMobile didn't do 3-way combi-SIMs. You need to phone up for replacement TMobile SIMs.
Hello there @afrs
I am very sorry this has happened.
Is your account, EE or T-Mobile?
Have you spoken to our customer service team?
Thanks, Leanne.
I'm EE customer!!!
That's worst than I thought!!!
They don't know I'm EE customer?
Wow!! That's incredible!
I'm EE customer!!!
Morning @afrs
If you give our customer service team a call they will get this looked into for you.
I am sorry the community has no account access to check this for you.
Thanks, Leanne.
What does texting NUMBER to 150 tell you? I believe that as well as telling you what your mobile no. is it also tells you the brand you are on.
