by GRGlaister
EE 4G Multi Sim
Hi,  Not fully up on how these things work.  My partner is wanting to buy an iphone SE outright and then purchase the EE 4G Multi SIM for £20 that is on offer.  Just wanting to check that buying an unlocked iphone from another provider won't stop me from using the EE 4G Multi SIM?
I'm sure this is probably an obvious question to most, but thanks for any help.
by Ace Contributor
Solution
Re: EE 4G Multi Sim
Hi @GRGlaister
If your iPhone is unlocked then yes you can use EE sim in your unlock without any issue.
Many thanks,
by Ace Contributor
Solution
Re: EE 4G Multi Sim
Hi @GRGlaister
Many thanks,
