by Iphonemaniac Investigator
Do EE offer a Pay & Go ESim for iPhone Xs Max
When I receive my unlocked iPhone Xs max I want to use it using an ESim, will EE offer a pay and go esim? Thanks
8 REPLIES 8
by Brilliant Contributor
Re: Do EE offer a Pay & Go ESim for iPhone Xs Max
Hello @Iphonemaniac,
Welcome to the community,
The E-Sim will not be available until an update later in the year from Apple, but I do not see why you cannot use a pay as you go SIM card, you can have a look at the shop and click on pay as you go.
Thanks for your reply, I will do that, do you know if EE will offer pay & go ESim? Also if I don’t receive my sim in time can I set up my iPhone without a sim? Thanks
With regard to the ESim, no idea, I suspect no one knows yet, as Networks do not have to make this available and could block it, according to Apple, you can read about it there.
Yes, you can set it up without a sim if you have wifi at home, you can then download and install apps.
If you have a nano sim already, you can insert it and use your new phone to make calls with it etc.
Excellent, thanks so much for your help
You are welcome, anymore questions you may have even when you get your new phone, you are welcome to ask here, and one of us will try and help where possible.
by Pooya79
New Member
Hey there
the update just been released so what should we do?
by Shabir1
Hi, Apple released iOS 12.1 yesterday and it shows their is support for e-sim. Can you confirm if it’s available and what the cost is?
Good Morning @Pooya79 and @Shabir1.
Welcome to the community.
The eSIM is now available. This can't be used on pay as you go.
If you wish to get an eSIM simply give us a call or visit your local store
If taken out over the phone we will send you your QR code in the post.
Katie 🙂
