Highlighted
Can't activate a replacement SIM
My old phone died so got a new one. It required a different size SIM so I ordered a replacement. The replacement requires activation by sending a text to the old phone, but it's dead. How can I activate the new sim? I called the support line, waded through some menus, and the recording just said to check online and hung up.
Highlighted
by Ace Contributor
Solution
Re: Can't activate a replacement SIM
Hi @kferr
Welcome to the EE Community,
If you call freephone 0800 956 3146 a tech advisor will be happy to assist you with getting your new sim activated.
Thanks,
David.
Highlighted
by Ace Contributor
Solution
Hi @kferr
Thanks,
David.
