by Foinaven84
Can I keep old phone number?
My old phone is kaput. Looking at Samsung Galaxy A10 and wondering if I can keep my old phone number?
by Brilliant Contributor
Solution
Re: Can I keep old phone number?
Hello @Foinaven84 ,
Yes, you just put your SIM card in a new phone, and if you are upgrading to a new phone you can also use the old SIM card, the same goes if you are buying your phone outright somewhere else, just put the SIM card in the new phone.
Solution
Hello @Foinaven84 ,
Recent solutions
