by aducard
New Member
Can I add a second number to the same plan?
Hello,
I am already a EE client and need to get a new phone number for work.
Can I get both numbers under 1 plan?
thank you
Solution
Re: Can I add a second number to the same plan?
@aducard  You’ll need a different contact for the new number as you can no longer get shared plans.   You will be able to gift data between both plans as they will be on the same account.
Solution
