by JJ1980
60gb plan only showing 30gb
I signed up for the 60gb plan but it's only showing 30, my allowance refreshed today?
by Ace Contributor
Solution
Re: 60gb plan only showing 30gb
Hi @JJ1980
Welcome to the EE Community,
I would recommend contacting 150 so they can rectify your problem if you have signed up to the black Friday 60GB 18 month SIM only deal for £20 the plan comes with 30GB and then they apply two free data add-ons to make it 60GB there have been cases where the system havent applied the add-ons customer services can apply them manually for you.
Thanks,
David.
by Ace Contributor
Solution
Hi @JJ1980
Thanks,
David.
by JJ1980
OK thanks David
by Jayd
Had exactly the same issue, called 150 they applied 2 data add ons, one at 20gb and the other 10gb eu and UK data , all solved now
Thanks for the update 🙂
Have a lovely weekend @Jayd
by Carla67
Thank you, I’ll give them a call once it arrives, maybe it will have the add ons.😊
Recent solutions
