by Pollygon
4g sim card, will it work on a 2g phone?
I've just signed up for a new 4g sim for my elderly mother but the phone I was looking to buy for her specifies that it won't work on 3 network as it does not support 3g, it is a 2g phone.
will this ee 4g sim card work on a 2g phone ?
Thanks .
by Ace Contributor
Re: 4g sim card, will it work on a 2g phone?
Hi @Pollygon
Welcome to the EE Community,
Yes a EE4G sim will work with 2G 3G & 4G.
by Pollygon
Thanks for your swift reply .
by Expert Contributor
Expert Contributor
@Pollygon which phone is it that you are looking at? Yes 4g sim might work but it might only work on 2g network!
There aren't many 2G only phones these days, if any. You can still get 3G feature phones cheaply. A 4G SIM will work in either by effectively downgrading itself.
