by padacol
will my htc one m8 work in canada?
am getting confused as to whether my HTC One M8 will work in Canada, am visiting later this year and was looking at using my phone for sat nav whilst there, but have seen conflicting reports as to its suitability on Canadian networks....
Solution
Re: will my htc one m8 work in canada?
Hi @padacol,
Welcome to the EE Community. Smiley Happy
Yes and no...
The HTC One M8 supports the majority of frequency bands used in Canada.
However, it doesn't support the 1700MHz spectrum which is used for 3G/4G data in some areas.
I would recommend using a sat nav service that allows you to download your maps in advance to be safe. Your phone's GPS will work even without a data connection.
Hope this helps.
Solution
Hi @padacol,
Yes and no...
Hope this helps.
by padacol
Thanks...
generally use Google maps as a sat nav these days, will just have to wait untill I get there and hope!!
Hi @padacol,
You can download maps to use offline in the Google maps app. Smiley Happy
Find out more over on the Google maps help pages.
