by karenllm
New Member
will it cost more to use my ee in iceland
Will it cost me more if i use my phone in iceland and is there anything I need to do
Solution
Re: will it cost more to use my ee in iceland
No, it is part of EU. You may use your usual allowances there with up to 15 GB data per billing month if you have more.
If you are on contract, remember to text ROAMING to 150 before you leave to check roaming is enabled on your account.
Solution
