by Rachelle60
will I be charged for calling my partners uk mobile in Germany?
My partner is going to work in Germany. I was told by customer services that if I call his uk mobile while he is there then I will be charged as it is an international call.
i then went onto online chat help who said as I was calling a uk mobile number it was included in my allowance. Can anybody clarify this?
we are both on EE pay monthly plans
by Ace Contributor
Solution
Re: will I be charged for calling my partners uk mobile in Germany?
Hi @Rachelle60
Yes you can call UK number free using your call allowance from UK while that number in Germany.
by Ace Contributor
Solution
Hi @Rachelle60
by Rachelle60
Hi
thanks for the response, I thought this was the case but after receiving conflicting advice from 2 EE employees I wasn’t 100% sure if things had changed
Hi @Rachelle60
I know @tahirmian has answered you already here, but just to add some back-up here, you can call a UK number within your allowances regardless of where they are in the world. 🙂
Hope this puts your mind at ease.
