by AndyHill67
New Member
why wont my phone work abroad despite having roaming on ?
Re: why wont my phone work abroad despite having roaming on ?
Hi @AndyHill67
Log into your online account and then menu - Manage device, make sure you have activated roaming and international calls.
Or
From the MyEE app current usage - controls, activate use phone abroad and make international and premium calls
Hi @AndyHill67
Welcome to the community.
If everything that @Northerner mentioned does not work for you, can you try connecting to another network as below?
  • iPhone > Settings > Mobile Data > Network Selection > Turn off Automatic
  • Android > Settings > More Networks > Mobile Networks > Network Operators > Tap OK
  • Windows > Settings > Mobile Network > Network Selection > Tap on start manual search
Let us know if this works for you 🙂
