by robi_b Investigator
why my EE sim card is not working in Gabon?
despite on the EE website Gabon is mentioned as a roaming country:
https://ee.co.uk/help/add-ons-benefits-and-plans/call-or-going-abroad/roaming-costs/countries/gabon
17 REPLIES 17
by Ace Contributor
Re: why my EE sim card is not working in Gabon?
Hi @robi_b
You need to turn your roaming on.
You can do this opening your my EE account or via app.
And you can find roaming charges details here.
Hi @robi_b.
That's great advice from @tahirmian!
Let us know if it fixes your problem or if you need any further help 🙂
Jon
If on contract, did you activate roaming on your EE a/c before you left UK?
Often just rebooting the phone is the simple remedy. Otherwise try logging into your My EE account online & go to Menu / Manage Device / Roaming Abroad and also Call Abroad and Premium rate. They will show as ticked if roaming and calling abroad is activated. If they are not ticked, can you activate these settings?
not working
did not work
pay as u go. did not activate it
it did not fix it
Do you have PAYG credit on your phone?
If it works what exactly does texting AL to 150 report?
Good Morning @robi_b.
Let us know what texting AL to 150 gives you as @XRaySpeX has suggested.
Has your phone worked abroad before?
Jon
I cannot text anything as my line is not working in Gabon.
The phone was working ok in the EU.
I have credit but cannot text anything as the line is not working here.
Are you able to try connecting to another network @robi_b?
This can be done in settings on your phone.
Is there anyone else with you who is using a UK mobile number?
Jon
by JMacD
Did you ever get a solution?  I am completely set up for roaming but the phone will not pick up a network even when trying to select a network manually.  There are two others currently with me in Gabon on EE who have the same issue.  Vodafone works fine.
Hi @JMacD,
Welcome to the EE Community.
What happens when you try to connect to one of the available networks?
It says: network not available on your card
at Vodafone works fine I wil defiRe: why my EE sim card is not working in Gabon?
No, I couldn't solve the problem. If you tell me that Vodafone works fine I will switch to one of their sim cards next time I'll go to the UK.
Hi there @robi_b
Thanks for coming back and letting us know.
When was the last chargeable activity on your phone?
Katie 🙂
