by beachguide Investigator
why are calls & text from UAE being blocked
Calls & texts from the UAE are not reaching me: are they being blocked for some reason. Does anyone know why?
EE Employee
Solution
Re: why are calls
Morning @beachguide
I would get your daughter to speak to the local network she's using.
Is she using a local network SIM card?
Thanks - Karen. Smiley Happy
8 REPLIES 8
by Profile closed
Not applicable
Re: why are calls & text from UAE being blocked
Hello @beachguide has roaming been enabled on your account? You can check by logging in to MY EE online and navigating to MY EE>Manage device:
https://id.ee.co.uk/id/login
Here is a link containing more information on setting up and using your phone abroad:
http://ee.co.uk/help/add-ons-benefits-and-plans/call-or-going-abroad/roaming-using-your-phone-abroad
Where are you? In the UK or the UAE? If you are in the UK, you are not roaming & calls & texts from UAE should be reaching you for free/
EE Employee
Hi @beachguide and welcome to the community.
So I can try to assist, please may I know if you are roaming or currently in the UK?
Many thanks,
Lee
Re: why are calls
My duaghter has been trying to text me on EE in the UK from her local UAE network. She has also tried texting a friend on the O2 network and neither messages have been received.
beachguide
by Profile closed
Not applicable
Re: why are calls
Hello @beachguide if it is the same for other networks as well as EE then this suggests it is a fault with the UAE network not your EE device or account. What device does she have? Has she changed the number to the international format +447123 456789 or 00447123 456789? 🙂
EE Employee
Solution
Re: why are calls
Morning @beachguide
Re: why are calls
Dear Karen.
She has contacted her local network and was told there was no
problem(?), however, a recent message to me took 24 hours to arrive!!
regards.
beachguide
EE Employee
Re: why are calls
Hi @beachguide
If it happens when she texts all networks it would point to being an issue with the local network
What happens when she tries to call you?
