by merin1950
New Member
using my phone in USA
what is the procedure for using my phone in the USA i an on monthly crontract
by Brilliant Contributor
Solution
Re: using my phone in USA
Hello @merin1950
Thank you for taking the time to visit the Community today. Smiley Happy
You will need to activate roaming on your account before you can use your phone abroad. You can do this by texting ROAMING to 150. You will also need to make sure, international calls are active, you can do this by signing into your MyEE Account or by contacting customer service on 150 from any EE phone.
You can check how much it will cost to use your phone in the US here.
Solution
Hello @merin1950
by Ace Contributor
Assuming you aren't on a new max plan, and if you are on a plan that supports it, the Travel Data Pass is available and good value most of the time.
£4 a day for 500MB data (from UK Midnight time) so if you land in NYC around 7pm, be careful you don't get charged a day for a few mins use, for example.
https://shop.ee.co.uk/international/travelling-abroad/travel-data-pass
Hello @merin1950
Thanks for coming here 🙂
I can see you have had some great help already.
Please do contact us before you go to make sure Roaming is set up for you.
Have an amazing time 🙂
