by Bomberboy467 Investigator
use in canada
I have this 4GEE Max Plan with a 24 month contract If I read it correctly use of the phone (texts, phone and data) is included.. am I right?
by Brilliant Contributor
Solution
Re: use in canada
@Bomberboy467, that is correct, but data is up to 15Gig inclusive, then you will have to pay for a add on if you use more, so a good idea is to use Wifi, if you need a lot of data.
Solution
Re: use in canada
Re: use in canada
thanks... just the job we have access to wi-fi in a number of hotels so 15gb should be just fine
Re: use in canada
Hi @Bombernoy467
I see @Schockwave has expertly answered your question.
Let us know if you have any more.
Have a brilliant time in Canada. 🙂
by Scholarly Contributor
Re: use in canada
Please note that the Max Plan must have been taken out on or after 10th May 2017.
If you are using data without an add-on it means you would have.
