by Nathan21
New Member
traveling
Because my work I travel alot sometimes I go out of the UK to Ireland, Jersey and Guernsey, will my 4g still work there ??
Solution
Re: traveling
@Nathan21 : Your mobile data will still work there with up to 15 GB data per billing month if you have more. Whether it'll be 4G is down to the local network you connect to.
If you are on contract, remember to text ROAMING to 150 before you leave to check roaming is enabled on your account.
Solution
Re: traveling
