by goanna
topup for China
hello
I use monthly topup in the uk because I am not always continuously in the uk, so it's a waste to have a contract plan.
I want to topup credit for use  in China, but I can see elsewhere that the normal topup plan "grabs" the usual monthly amount, which I don't want to use.
How should I topup so that only my actual usage will be deducted?
Thankyou
by goanna
pay as you go and China
I use pay as you go in the UK.  When I topup the money is grabbed and used for my plan.  I want to top up so this doesn't happen and I have credit for roaming in China and the occasional necessary call or text.  What must I do?
Thankyou
EE Employee
Re: topup for China
Hi @goanna and welcome to the community.
Please see how to stop packs on our EE pack help guide.
Many thanks,
Lee
Re: topup for China
Text STOP PACK to 150 before you next top-up & you can use the SIM as normal PAYG at standard per-unit rates. Be aware you can only call & text from your credit; data can only be had from a roaming add-on.
