by Bode39
sim for wifi hub abroad
I've got an EE wifi hub which ive never use, and am just about to set up.
Which payg SIM option would be best to use abroad ?Initially Spain and Andorra ?
Solution
Re: sim for wifi hub abroad
Whichever SIM you get its supplied allowances are only for UK. To use it abroad you will need to top-up sufficient to buy a data roaming add-on - see http://explore.ee.co.uk/roaming/ee/spain .
by Profile closed
Not applicable
How long are you planning on using it for though, as it sounds like you are based outside the UK now?
The only reason I ask is because all UK & EU mobile networks (including EE) now only allow roaming in another country for up to a maximum of 30 days at a time.  After that point you have to connect to the 'home' network again (in this case EE) to continue with service.
Solution
That condition only applies to contracts not PAYG.
by Bode39
Thanks very much
