by HicNic
roaming
Hello,
What is the easiest way to use my data in China?
Does it work as usual?
by Ace Contributor
Solution
Re: roaming
Hi @HicNic
here is a link that will tell you everything you need to know regarding using your data, setting it up and any costs. xx
https://ee.co.uk/help/add-ons-benefits-and-plans/call-or-going-abroad/roaming-costs/countries/china
by Ace Contributor
Solution
Re: roaming
Hi @HicNic
