Highlighted
roaming in canada withsmart plan 4g 100gb
am I going to be charged for calls and data in canada
Highlighted
by Ace Contributor
Solution
Re: roaming in canada withsmart plan 4g 100gb
Hi @rogeriko
Welcoke to the EE Community,
If you have the roam further swappable you won't be charged.
Thanks,
David.
Highlighted
by Ace Contributor
Solution
Hi @rogeriko
Thanks,
David.
Highlighted
after searching the EE site for an hour I found the swappables.   What the hell is that all about?? Add-ons and swappables, talk about total confusion. Why not just say Roaming on or off. Bunch of nonsence but anyway my daughter will not be paying any roaming charges because her "swappable" is active. Thanks anyway..  Roger.
Highlighted
by Ace Contributor
@rogeriko sorry I should of included a link for the swappable benefits.
tell her to text ROAMING to 150 to make sure roaming is active on her account.
Recent solutions
