by nrager14
roaming deactivated in vietnam
I am in vietnam, I have always had roaming activated on my account, but have just upgraded and it seems to have been taken off. How can I reactivate it, as I cant call customer services and cant access voicemail or make calls...
Re: roaming deactivated in vietnam
You may still be able to activate it in your online a/c under Manage Devices. If not, you will need to call EE. Use the landline nos. in my sig. over Skype.
by nrager14
Ok, so looking at manage devices, roaming is already active. But when I call any number, including customer service or voicemail, I get a message saying the number dialed is incorrect. (I have tried all the variations on international codes - 0044, +44, and UK normal codes, none work.
Could this be a problem with vietnam specifically? I have also been able to send a text, so it is just calling.
Thanks for your help
by Profile closed
Not applicable
Try a manual network search and see if you can roam on any other mobile networks.
Hi @nrager14,
Thanks for joining the EE Community.
Did the manual network selection @Profile closed suggested help?
