by rafsky Investigator
roaming Jersey
I’m in Jersey at the moment i have receive message that i can use the data , it show my display 3g but not connecting or sending data any ideas ?
9 REPLIES 9
Re: roaming Jersey
Hi @rafsky
Thank you for joining the EE Community, it's great to have you on-board. 🙂
Yes, all our 4GEE Essential plans, 4GEE plans and 4GEE Max plans will let you take your allowances with you to the EU.
You can see more information on the new roaming changes on our What EU roaming changes mean help and support page.
As you're unable to connect to the data service, I recommend giving our roaming troubleshooting a try.
Please let me know how you get on.
Chris 🙂
Re: roaming Jersey
i can see 3g t mobile on my tablet but when i want to open a web in abrowser
- no internet connection ?
what shoul i do no w
Re: roaming Jersey
Thanks for getting back to me @rafsky
When you do a manual network search, what other networks come up?
Re: roaming Jersey
Sure 3g
Sure 2g
JT-Wave 3g
Jersey Telenet 2g
Jersey Telenet £g
JT-Wave 2g
so could you advise which should be use ?
Re: roaming Jersey
Thanks @rafsky
My advice just try any of the 3G networks, until you get one that works 🙂
Fingers crossed you get a better connection, let me know how you get on.
Re: roaming Jersey
Have try all of the 3g ,and no luck  , what now ?
Re: roaming Jersey
Thanks for trying @rafsky
If it is just a data issue, please check to make sure your data roaming is switched on in your settings:-
Android: Settings >>> More >>> Mobile Networks >>> Data Roaming
Or
Apple: Settings >>> Mobile Data >>> Mobile Data Options >>> Data Roaming
If it still isn't working, I recommend giving our customer services team a quick call, they have access to your account and will be able to help.
Re: roaming Jersey
yes its on and as i say before i can se 3g with small R (on roaming )but for some reason its not connecting to the data ?
Re: roaming Jersey
Thanks @rafsky
I suggest calling our customer services team. They will be able to look into this and get you up and running. 🙂
