by clements747 Investigator
phone in canary islands incoming calls fine outbound not
 relatives phone in canary islands, incoming calls fine,however outbound is not possible despite  account on max plan and roaming enabled worked fine week before in mainland spain any ideas people, it does show 4G and Movistar and is in lanzorote
Solution
Re: phone in canary islands incoming calls fine outbound not
Hi @clements747.
When you try a manual network search, what networks are available?
Are there any other EE phones with you at the moment?
Jon
6 REPLIES 6
If on contract, did you activate roaming on your EE a/c before you left UK?
Often just rebooting the phone is the simple remedy. Otherwise try logging into your My EE account online & go to Menu / Manage Device / Roaming Abroad and also Call Abroad and Premium rate. They will show as ticked if roaming and calling abroad is activated. If they are not ticked, can you activate these settings?
im the account holder so via ee website on account and checked 1.roaming enabled,2 i phoned her and she answered thus proving roaming is fine plus she was in Barcelona last week and it worked there a ok tried manual selection of network just in case made no difference, i will phone CS in the morning.
I work for EE anyway and will do the necessary in the morning thankyou
Did you check both ticks? You only mention 1.
Solution
Hi @clements747.
Jon
After speaking to Cs this morning Orange ES worked Movistar was a stronger signal but doesn't appear to be the roaming partner in the Canary Islands So a network Manual selection was required
Thanks for coming back to us with an update @clements747
Hope you have a great time 🙂
