by Ale07map
outgoing calls
  1. Am abroad and unable to make outgoing calls how can I solve this problem
by Profile closed
Not applicable
Solution
Re: outgoing calls
Hello @Ale07map has roaming been enabled on your account? You can check by logging in to MY EE online and navigating to MY EE>Manage device:
https://id.ee.co.uk/id/login
Here is a link containing more information on what to do when having problems roaming abroad:
https://community.ee.co.uk/t5/Roaming/Roaming-with-EE-What-to-do-if-you-re-having-problems-abroad/td...
by Profile closed
Not applicable
Solution
Re: outgoing calls
