by Nikkidonnachie
not able to call in turkey
Hi my mum is currently in turkey and has the 60 minutes global roaming but has tried to make a call but it says call assisted then cuts off can anyone help please?
by Ace Contributor
Solution
Re: not able to call in turkey
@Nikkidonnachie to check your roaming enabled please click here Manage your device  it take you to login my ee web account  where you can see  click on that hopfully it will start working for you,
Many Thanks
@Nikkidonnachie  Was roaming enabled on the account before leaving the UK ?  Purchasing add-ins does not enable roaming on the account.
by Ace Contributor
Solution
Many Thanks
by Nikkidonnachie
Thank you very much for your help she hadnt set it up! But all sorted now
by Ace Contributor
@Nikkidonnachie You are welcome, glad to know that.
Many thanks
EE Employee
That's great news @Nikkidonnachie
If you need anything else you know where we are.
Thanks - Karen. Smiley Happy
