by mksteveuk Investigator
my tplink mifi device doesn't get an internet connection in the Netherlands
Was hoping to use my allowance whilst on holiday, but the tplink is connecting to T-Mobile and not allowing any data.
Are there settings to allow this to work?
7 REPLIES 7
Re: my tplink mifi device doesn't get an internet connection in the Netherlands
@mksteveuk : Is it on contract or PAYG? Can you send/receive texts?
It is payg. Texts seem to work
Have you a data add-on? Go to http://add-on.ee.co.uk/status to check.
6GB of data which will expire after 3 months. It can be used in the UK & EU with the fastest 4G UK data speeds.
Waiting5.9GB left (using different wifi)
Hi @mksteveuk,
Have you tried selecting a different network manually?
I can see
T-Mobile-NL
NL-KPN
vodaphone-NL
Tele2 NL
Which is the correct network for EE roaming?  Are there settings and passwords to help?
Just try each of them and see which one connects, @mksteveuk.
You shouldn't need settings and passwords.
Let us know how you get on.
