by Flynny2
in Fuerteventura
Am in Fuerteventura no phone signal,  annoy contact EE, roaming on no 4g or anything,  an anyone help?
Re: in Fuerteventura
@Flynny2  Did you text ROAMING to 150 before you left the UK ?
by Flynny2
Been here for the last 8 years, never a problem in the past. Checked my account settings, roaming is activated. Checked usual things, phone off then on, disabled 4g, cannot get any other carriers
@Flynny2  It could just be a network issue there if roaming is activated on your account.
Hi @Flynny2
Welcome to the community, I hope you're having a fantastic time in Fuerteventura so far. 🙂
What kind of phone do you have?
Have you tried a manual network search?
Device type Steps
Apple Settings > Carrier > Toggle Automatic OFF
Android Settings > More Networks > Mobile Networks > Network Operators > Tap OK
Windows Settings > Mobile Network > Network Selection > Tap on start manual search
