by MTA
how to avoid high phone bills when abroad
Re: how to avoid high phone bills when abroad
Hi @MTA
Where are you going and what plan are you on?
You can check out roaming cost and add ons here.
Hello there @MTA
Welcome to the community.
Where will you be travelling to?
If you have a Pay monthly, Pay as you go, Flex, or Mobile Broadband plan with us you can use your calls, texts and up to 15GB of data within 48 EU/EEA destinations
If you have a Max Plan started after 10 May 2017, you can also use your minutes, texts and up to 15GB of data within 53 destinations including Canada, Mexico, Australia, New Zealand and USA.
If you are travelling to any other country see the great link @Northerner has provided for costs and any add-ons we have available to reduce costs 🙂
Before you go make sure roaming is set up on your account by texting ROAMING to 150 and you'll receive a text with details about your roaming status and how to activate roaming if needed.
Have a great time 🙂
