by iulian14
New Member
hi in 2 hours i go in romania and i want to know if i can use my data
Hi
i need to go in romania for 2-3 weeks and i want to know if i can use my data and if i can make calls in romania
my phone is lock on ee and i cant use romanian sim
i have like 18gb left data and i want to use in romania
Re: hi in 2 hours i go in romania and i want to know if i can use my data
Txt ROAMING to 150.
If it comes back saying you are activated then all is fine. If not you need to call CS on 150 and ask them to activate roaming.
@iulian14   You Cannot Use no More Than 15 GB of Data Abroad in Any one Month.  Your calls and texts will be used from your call and text allowance whilst in the EU.
Please have a look at THIS
Hi @iulian14,
Thanks for joining the EE Community.
Did you get all the information you needed from @Northerner and @Chris_B's posts?
