by CaFiro Investigator
getting international call barring removed
Yesterday I bought an international pack so that I could keep in touch with a sick relative while travelling in France. I was assured it would work. Now I am here all phone calls are barred. I need urgent help to remove bar. I was promised I would not have a problem!
7 REPLIES 7
Re: getting international call barring removed
I’m using Apple XR.
@CaFiro : If you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150?
Often just rebooting the phone is the simple remedy. Otherwise try logging into your MyEE account online & go to Menu / Manage Device / Roaming Abroad and also Call Abroad and Premium rate. They will show as ticked if roaming and calling abroad is activated. If they are not ticked, can you activate these settings?
PAYG is auto enabled for roaming. You don't need to & can't do any of the above.
I’m on pay as you go international pack. So cannot see the option on manage device. I was assured it was all ready to go in store without needing to do anything
Was it an International SIM you bought, not just a Pack? Did you use the SIM in UK before going abroad? EE SIMs need 1st activating on the EE UK home network.
I used it to call a number to check the sim was active. But did not send msgs.
Purchased an international sim with an international top up pack
Hi @CaFiro
Did you make the call whilst in the UK?
If so, we will need to get this looked into for you, if you give us a call from another phone on +44 (0) 7953 966 250, we will be able to help.
Thanks.
