by 9cool10
error 10 in finland
i am using a pixel in finland (originaly from the uk) by data works fine but i cant call and text anyone despite having unlimited calls and text from within the eu. any help is much apreciated. my phone says error 10.
Re: error 10 in finland
Good afternoon @9cool10
Thanks for stopping by community 🙂
Is your data working on WiFi only or over the network?
Did you activate Roaming before you went away?
Have you tried to manually search for a Network?
To do this.
  1. From the home screen, tap Apps.
  2. Tap Settings.
  3. Tap More.
  4. Tap Mobile networks.
  5. Tap Network operators.
  6. Tap the required network.
The network has been manually selected.
Let me know how you get on.
Thank you
Richard
