by TuckA
data roaming
travelling in Italy. phone and text working fine, data is not. please can you advise how to get data roaming working
Re: data roaming
Hi @TuckA
Hope you're having a great time. 🙂
Please try the steps below to get your data activated:-
  • To use data abroad you need to purchase a data roaming add-on, once you get to your destination.
  • Just try and access the internet on your phone or device and you’ll be directed to the EE add-on page - or got to http://add-on.ee.co.uk/status.
  • To see all of the available data roaming add-ons check out the Roaming pages.
  • 4G is only available in selected countries on certain networks, you can see the list of available networks on the Roaming Help page.
  • Try re-booting your device and doing a manual network search.
How to do a manual network search:-
iPhone – Settings > Carrier > Toggle Automatic OFF
Android – Settings > More Networks > Mobile Networks > Network Operators > Tap OK
Windows – Settings > Mobile Network > Network Selection > Tap on start manual search
Please let me know if that helps you get connected.
Chris 🙂
