by Paulwb65
data roaming in Belarus
I am going to Belarus next week for four days, what will the data usage be like as in terms of cost and access
by Ace Contributor
Solution
Re: data roaming in Belarus
Hi @Paulwb65 You can check out the costs here.
Use up to 5MB of data in the country you're travelling in for just £36 a day.
Check you have roaming enabled by testing ROAMING to 150 now to confirm.
by Ace Contributor
Solution
EE Community Team
Morning @Paukwb65,
I can see that @chistery has given you all of the roaming costs and bundles available for Belarus 🙂
The community roaming post has everything you need to ensure you are set up before you travel.
I hope you have a great time and get to see some of the country while you are working 🙂
Alex 🙂
